vhsh
vhsh
Postby lou » Thu Jul 03, 2014 12:43 pm
Slight Concern ....running standard ts1, pm28 pipe, VHSH 30m ....always had a little trouble jetting it right ...Concerns are gone down to a
DP 264 atomiser,.. U16 needle on top clip .. which seems very clean almost to lean but a nicer ride , come down a clip boggy mid range!!
Most Recommendations for this combo telling me dp266 atomiser, u16 needle 150 main ...... to be careful running the dp264!! tried Various K needles
K8 K5 K21 which have all resulted in no joy ...
Anyone else on such a lean set up ??
lou
Re: vhsh
Postby Toddy » Mon Jul 07, 2014 6:22 am
I run a VHSH on two scoots set up below for mine never had any joy with the U Type Needles
Dellorto 30mm Flatslide (Taffspeed) VHSH/Devtour No Filter
Slide 50
Needle K94 P4
Atomizer DQ269
Main Jet 160
Pilot 45 40
Choke 60
Float (Needle Valve) 300
Return to Carburettors
