Flywheel
Flywheel
Postby Blaginit » Mon Jul 27, 2015 3:12 pm
Just got lightened flywheel with bgm electronic kit only trouble is my old flywheel was long finned new one is short do you think this will cause a problem with avanti kit also do I need a new flywheel cowl any advice welcome
Blaginit
Re: Flywheel
Postby Adam_Winstone » Mon Jul 27, 2015 5:17 pm
The short fin flywheel will not cause issue with the Avanti BUT you will need to get hold of a cowling that was designed for use with the short fin flywheel. If the fins are not reasonably close to the cowling then it does not circulate air efficiently.
Adam
Re: Flywheel
Postby speedy » Tue Jul 28, 2015 11:20 am
Just to add to, I'm pretty sure that the Indian long fin flywheel that was introduced to later models to aid cooling, actually didn't do anything. Read/ heard somewhere that tests were done which showed this? My long finned ones I've had shortened and machined to mid weight by AF anyway. Cheers,Speedy.
speedy
Users browsing this forum: Google [Bot] and 3 guests
