af cassette clutch fitting help!
Postby Cutdown69 » Sat May 23, 2015 10:22 pm
I run a ts1225 with cyclone box
Just bought the cheaper version cassette clutch
slotted it on, torqued up the nut, put the cap on and refitted sidecasing
after a bit of a fiddle with cable and reffiting brass nipple, went to depress lever and it was rock solid virtually..couldnt depress it all the way to handlebar
i opened up casing again to check plunger was ok, and bolted up..still same problem..you would would have to be popeye to work that lever
feel gutted..am i doing something wrong?
Cutdown69
Re: af cassette clutch fitting help!
Postby missing lynx » Sun May 24, 2015 12:20 am
have you tried compressing it with a clutch compressor or in a vice to make sure it will compress as there could be something in the basket stopping it
Postby jonashford » Sun May 24, 2015 7:09 am
check the ears of the clutch plates are not catching on the sprocket
jonashford
Postby Cutdown69 » Sun May 24, 2015 9:26 am
i'll take it out and have an inspection
was tired and p'd off last night
thanks
Cutdown69
Postby pharrisRB225 » Sun May 24, 2015 9:50 am
Mine was the same, I just took the cassette out of the basket and tried it in different positions until I was happy with it not catching, it's been perfect for the last couple of years.
pharrisRB225
Postby bazza3004 » Sun May 24, 2015 11:32 pm
wasn't there something regarding some folk having clearance issues with the xmas tree/clutch nut ?
bazza3004
Postby Cutdown69 » Tue May 26, 2015 7:38 pm
This could be my problem
i have a cyclone so may be cluster is blocking compression
was there a solution.?
Cutdown69
Postby bazza3004 » Tue May 26, 2015 9:46 pm
Hi i cant be 100% on this but think they either cured it by shimming or ground down thread on end of xmas tree that were protruding through nut. I could be talking b#####ks mate but sure there was something on erotica forum on this subject.
bazza3004
Postby bazza3004 » Tue May 26, 2015 9:55 pm
Just done a search on there and as i stated some have had to remove some of the exposed cluster thread above the nut as it fouled when clutch was compressed. Others with the road version had to stip them and file burrs etc off turrets to allow plates to move freely. Cheers. Baz
bazza3004
Postby Cutdown69 » Tue May 26, 2015 10:00 pm
Ok thanks
Cutdown69
Users browsing this forum: Google [Bot] and 2 guests
