'64 pacemaker resto
Re: '64 pacemaker resto
Postby Nobby » Mon May 18, 2015 4:51 pm
Yep! Well done for spotting that!, Handlebar choke... The only thing Iv yet to do!, got to make a bracket coming off of the throttle/ switch housing....
Nobby
Postby Nobby » Mon May 18, 2015 4:56 pm
Dimitrios_231 wrote:What brand is the kick start shaft piston?
I bought 3 Casa recently...
Yes Dimitrios just the piston.., can't remember where I brought it from now!!
Nobby
Postby dave411 » Mon May 18, 2015 7:37 pm
MB
dave411
Postby Dimitrios_231 » Mon May 18, 2015 7:54 pm
Thanks,
the choke lever will look cool on the handlebars ;)
I will use one on the bridge on the next lammy.
Dimitrios_231
Postby Chadley » Mon May 18, 2015 8:29 pm
Nobby wrote:Changed the font of the front number plate letters to... Which was bugging me!
Looking good. That number plate font is much better.
Did you manage to sort out the brake light switch?
Nice to see that you've had time to give the grass got a trim too... :lol:
Chadley
Postby Nobby » Mon May 18, 2015 8:36 pm
dave411 wrote:MB
Nar....it was either scooter restos, scootopia or Camb lamb!.... Can't remember which one :?
Nobby
Postby Nobby » Mon May 18, 2015 8:44 pm
Dimitrios_231 wrote:Thanks,
It's fooked op that the choke works the opposite way right isn't it?!!, so you have to have the choke lever pulled fully on to have choke off..... And let the lever off to put the choke on! :|
Nobby
Postby Nobby » Mon May 18, 2015 8:57 pm
Cheeky!! :D ,
I had to cut and weld switch up !! Because I forgot to order one in time !!
I've had my flywheel remagnatised and everything works but the lights are dim as fook!! Earths seem fine...Any tips anyone??
Nobby
Postby Adam_Winstone » Mon May 18, 2015 9:17 pm
Try another stator?
Postby Dimitrios_231 » Mon May 18, 2015 9:24 pm
Nobby wrote:It's fooked op that the choke works the opposite way right isn't it?!!, so you have to have the choke lever pulled fully on to have choke off..... And let the lever off to put the choke on! :|
Υes this is how it works,in reality it is an air valve inside the slide,with the valve fully open the engine runs normal,with closed valve less air leads to a richer mixture,
it is very useful if the jetting is lean and you can listen/feel the piston rings before a seizure,
remember to let the lever off trying to save the situation :)
If the flywheel is remagnetised and the lights are still very dim,the easiest and cheaper way is to try smaller wattage lamps.
Dimitrios_231
Postby Scooterslag » Mon May 18, 2015 10:21 pm
Nobby wrote:
dickie wrote:
Nobby wrote:
Reverse pull... No dampers..... Progressive springs...
I'm about to convert my drum to reverse pull (it's effing terrifying the way it is). Where did you get that cable guide; it looks a lot more 'period' than the anodised ones I can find.
Cambridge lambretta or all styles do them I think
Have to excuse my ignorance but how do you put together a reverse pull drum set-up , been looking at the picture but can't quite figure out where the cable runs through and how it all goes together? Paul
Postby Chadley » Mon May 18, 2015 10:24 pm
My 6V AC lights are pretty dim at tick over. What's it like at higher rpm? Should be much better and okay for MOT purposes.
Are you running a standard 6V 25/25W incandescent headlamp bulb with a 6V 5W tail lamp and 12V 3W for the speedo? If you're using a higher wattage headlamp such as a 35/35W, it may actually be dimmer at low revs.
I notice that you have a UK DC battery type regulator/rectifier and stator but then seem to have an AC chassis loom with no battery. Shouldn't affect headlamp but brake light is likely to be dimmer at low rpm as it will be fed solely from stator rather than from DC battery.
Chadley
Postby Nobby » Tue May 19, 2015 6:31 am
It's pretty much as it says on the tin Paul!.... Inner and outer are reversed, all you really need is one cable adjuster and a 10mm nut!...cut the outer down to size and have it going into the brake arm with an adjuster and connect the inner and original adjuster to where the outer usually goes (with nut instead of brass adjustment disc). When you pull the lever the outer cable pushes the brake arm instead of the inner pulling it doyagitmi?
Nobby
Postby Nobby » Tue May 19, 2015 6:35 am
I think it is an battery loom, the brake light and mains aren't a prob really it's the rear light and the side light which are like little glows..... Now I'm writing this in thinking how is one ok and not the other and maybe there's a dry connection!..... Will put a multi meter on um today....
Nobby
Postby Nobby » Wed May 20, 2015 10:39 am
Nobby
Postby bolzenanker » Wed May 20, 2015 10:41 am
Tidy.
bolzenanker
Postby pacemaker » Wed May 20, 2015 11:39 am
Nobby interesting switches on the 64 pacemaker . would you say they are original?
pacemaker
Postby Nobby » Wed May 20, 2015 11:40 am
Woop woop!! ... Back on the road!
Nobby
Postby Nobby » Wed May 20, 2015 11:41 am
Gt150??!
Nobby
Postby Cgt75b » Fri May 22, 2015 11:33 am
Great looking scooter, enjoy.
