by MK Monty » Mon May 04, 2015 12:17 pm
Was it loose or was the key snapped and thats a new one?
Personally I would remove the key and get some valve grinding paste on it and lap it in. You will then have a dull ground area and get a better idea of how much area is damaged as it wont be dull.If they are ground and matched with a new key it should be OK. Also check that the new key is not too high or it will hold it off the taper and it could chatter.
MK Monty
by davedidsmith » Mon May 04, 2015 1:44 pm
same key, flywheel has only done around 10 miles since changing same.
davedidsmith
by dave411 » Mon May 04, 2015 2:09 pm
Flywheel not seated correctly.Is it the correct one for your crank?
If so,as said,lap it in until its all dull grey,the check you key isnt to high.Maybe file it to make it not protrude as much.The key is only to put the flywheel in the correct position,its held on the taper.Make sure you torque it to the correct value too.
dave411
by Shaun » Tue May 05, 2015 11:30 pm
When I enlarged the pics on Photobucket, they look like grooves in the surfaces, not scratches.
From what I saw, the crank is scrap and will never lap in to a useable state.
Shaun
Users browsing this forum: No registered users and 173 guests
