sx 200 headset
sx 200 headset
Postby a-teamlambretta » Sun Apr 26, 2015 8:27 pm
Got round to assembling my sx 200 bought as about 80% complete. The head set is missing it's throttle and gear rods and wheels. It's a 1966 so what length rods and what type of wheels I.e plastic or brass?. Cheers Simon
a-teamlambretta
Re: sx 200 headset
Postby hullygully » Mon Apr 27, 2015 10:09 am
plassi I think buddy, same as GP :D
Re: sx 200 headset
Postby ahutch7 » Mon Apr 27, 2015 10:23 pm
310mm length rods and brass wheels.
Cheers,
Hutch
ahutch7
Re: sx 200 headset
Postby a-teamlambretta » Tue Apr 28, 2015 3:45 pm
ahutch7 wrote:310mm length rods and brass wheels.
Cheers,
Hutch
cheers for the info hutch 8-)
a-teamlambretta
Re: sx 200 headset
Postby Adam_Winstone » Tue Apr 28, 2015 7:10 pm
The Official Home Workshop Manual 4th and 5th edition lists the change to nylon control cable wheels on page 64 as being applicable to late GT200 and J125, whereas the 3rd edition shows the early TV/GT headset with the brass items. If this change was introduced for late GT 200s then it is unlikely that any of the later SX200 models were ever fitted with brass wheels.
Although, as with all things Lambretta... never say never!
Adam
Re: sx 200 headset
Postby a-teamlambretta » Tue Apr 28, 2015 7:25 pm
So mine being an early sx it will have the brass wheels?
a-teamlambretta
Re: sx 200 headset
Postby Adam_Winstone » Tue Apr 28, 2015 8:18 pm
No, early GTs would have brass, later GTs would have nylon/plastic. As the SX came after the GT, all SXs should have plastic.
The only update info that I can find for these parts changing spec' is the official dealer update sheet S/40 12.5.1965 for all SIII models, which details modifications to "Handle bar - legshield - throttle and gear controls"
This lists the 'roller' (control wheel) as being updated but no other specific material details are given. As I don't know of other modifications to these parts, I would assume that this is the change from brass to nylon (supported by the timeline of my previous comment). If this is the brass to nylon modification then the 1965 date ties in perfectly with this being a pre SX model change, supporting that all SXs should (should) have nylon control wheels as standard.
Unfortunately, Innocenti throw up lots of examples that don't follow the supported texts and timelines so I tend not to trust the 'must be' approach, hence my use of 'should'.
NB: You can fit either type, providing you have the matching rods and throttle tube/gear support to match. As it says in Sticky's and Dave Webster's tuning manual (RIP), many people have retro fitted the earlier type to eliminate slop, which can be caused by wear to the later type. As such, you cannot trust any restored example to accurately reflect what might have been fitted at the factory. If you are replacing control wheels then you must swap like for like.
Cheers.
Adam
Re: sx 200 headset
Postby a-teamlambretta » Tue Apr 28, 2015 10:08 pm
Adam_Winstone wrote:No, early GTs would have brass, later GTs would have nylon/plastic. As the SX came after the GT, all SXs should have plastic.
Cheers.
Adam
Thanks Adam for the info.
a-teamlambretta
Re: sx 200 headset
Postby a-teamlambretta » Tue Apr 28, 2015 10:11 pm
hullygully wrote:plassi I think buddy, same as GP :D
a-teamlambretta
Re: sx 200 headset
Postby Dimitrios_231 » Wed Apr 29, 2015 7:52 am
I've worked on three 66 SX200,all of them had black nylon/plastic rollers.
I have some NOS rods somewhere I'll measure them (right on the picture)
Dimitrios_231
Re: sx 200 headset
Postby ahutch7 » Wed Apr 29, 2015 9:57 am
Just to throw a spanner in the works, my first SX200 that I bought new in 1966 definitely had brass wheels.
ahutch7
Re: sx 200 headset
Postby Adam_Winstone » Wed Apr 29, 2015 11:50 am
^... exactly why I say 'never say never' with Innocenti specs even when the documentation suggests otherwise.
I have no reason to doubt that yours did, however, with very few unmolested/unrestored examples available to us, it is very important that we document those few examples that are still around to support people's claims. My own experience with GP specifications have shown period documentation to be flawed and I'd actually be somewhat surprised to find that all SX documentation was accurate.
Adam
Edit: I've just heard back from a pal who has a wonderfully original 1967 SX150 (early traits: bolt-in buffers, shield badge, handle panels, etc.) and that has nylon cable wheels for the throttle and gear cables. Whilst the SX150 was launched after the SX200, so can't be used to definitively state what an SX200 should have, it does show that early SX150s were fitted with nylon.
Funnily enough, this bike is SO original that Scootopia, who know this specific bike, refused to sell my pal a pair of weld-on damper brackets for it as it is too good an example to upgrade :lol:
NB: This is not proof, just a supporting example.
Re: sx 200 headset
Postby Dimitrios_231 » Wed Apr 29, 2015 7:51 pm
The rod is 28cm,code is 19762080.
Dimitrios_231
