by Brash » Sun Apr 26, 2015 7:31 am
Anyone know whether these are as good as its Italian original counterpart? Especially in a powerful engine setup and has anyone used one?
Brash
by lambypolo » Sun Apr 26, 2015 8:21 am
We got a sample at work and we were disappointed to see the cluster was drilled for the pressure plate like early versions.
I don't know what happened to the sample or how good the gearboxes are. From memory the machining was OK.
lambypolo
by Wack » Sun Apr 26, 2015 9:16 am
Don't know if they're made at the same place but I've seen a few of the AF close ratio ones with excessive wear. Personally I like the drilled cluster, seems to prevent the pressure plate tilting causing drag.
Users browsing this forum: Bing [Bot] and 10 guests
