Shock Absorber Shaft
Postby Dimitrios_231 » Fri Apr 10, 2015 9:30 pm
I've never changed an engine shock absorber shaft,is it an easy job?
Do I need any special tools?
Dimitrios_231
Re: Shock Absorber Shaft
Postby Wack » Sat Apr 11, 2015 9:31 am
I'd guess its lots of heat and a hydraulic press to remove. Why do you want to change, stripped threads?
Postby Dimitrios_231 » Sat Apr 11, 2015 10:15 am
Thanks,
One has came loose,I just need to re-fit it,I'm thinking of using heat and applying gently some pressure with a small vice.
The other case has a longer Spanish shaft that I want to replace with a shorter Italian.
Dimitrios_231
Users browsing this forum: Martin s and 13 guests
