Bodged
Bodged
Postby Captain Pugwash » Mon Mar 30, 2015 7:04 pm
I was helping a mate with a rebuild of his engine today he's fitting a BGM pipe Dellorto 28 PHBH and we were going to mildly re-port the barrel and we were also fitting a new mag housing crank and drive bearings.
All the new bits were had arrived but half way through the work we realised we didn't have the large circlip for the mag bearing, so I remembered that I had an old Li 150 engine, and I thought I would take quickly take it apart and get the maghousing off and use the circlip.
When I took the flywheel off the Li engine this is what I found.
:shock: :shock: :shock:
Not exactly what I was expecting. Even the outer seal has been put in back to front. Up date was that it did at least have a usable circlip 8-)
Last edited by Captain Pugwash on Fri Apr 03, 2015 12:59 am, edited 1 time in total.
Captain Pugwash
Re: Bodged
Postby Rich Oswald » Mon Mar 30, 2015 8:12 pm
Hell fire, that's some bodge that!
Re: Bodged
Postby Adam_Winstone » Mon Mar 30, 2015 8:22 pm
Good effort!
Re: Bodged
Postby terryj » Mon Mar 30, 2015 8:57 pm
i brought an indian engine of the evil bay
when i opened it up it was an odd ball kelvinater engine
welded up around main bearing like that one and all around the end plate studs as well so ended up with lots of bits to put into another engine if they will fit
mag housing is like an li without the spacer
li 150 gear box as far as number of teeth goes
so it will be an interesting build if i ever get around to it
terryj
Re: Bodged
Postby MK Monty » Mon Mar 30, 2015 9:04 pm
On the basis of its not pissing oil I would call that fixed. Not prety. Have we all gone soft in our old age. Remember we fixed these ruddy things with bed scanners and tube spanners that you hit with a hammer to make it fit. Tig welding what's that
MK Monty
Re: Bodged
Postby Captain Pugwash » Mon Mar 30, 2015 9:27 pm
MK Monty wrote:On the basis of its not pissing oil I would call that fixed. Not prety. Have we all gone soft in our old age. Remember we fixed these ruddy things with bed scanners and tube spanners that you hit with a hammer to make it fit. Tig welding what's that
I don't think its air tight, and both seals in the maghousing were in back to front.
I think Its looking much better now with the new maghousing on, the engine case itself still needs a good clean but the maghousing and all the shiny new bits inside that can't be seen do look much better.
The exhaust port had to be opened out a little and blended to match the stub.
I was surprised at how much of the cooling fins had to be removed to fit the stub for the exhaust, but I really should have expected that as it is quite a large diameter down pipe on the BGM exhaust.
The original broken mag flange pictured on top of the rebuilt engine.
Captain Pugwash
Re: Bodged
Postby modster79 » Tue Mar 31, 2015 6:21 pm
It most probably cost more in time and money welding it than it would of cost to buy a new one
modster79
Re: Bodged
Postby Captain Pugwash » Tue Mar 31, 2015 6:54 pm
modster79 wrote:It most probably cost more in time and money welding it than it would of cost to buy a new one
That's exactly what I said when I saw it, thinking about it now that was the second thing I said... After WTF :lol:
Captain Pugwash
Re: Bodged
Postby autobahnos » Thu Apr 02, 2015 6:09 pm
Thanks for the strip & build mate. I'll sort the parts out this week, that Mag Housing was a belter to see. :D
autobahnos
Re: Bodged
Postby joe swoonara » Thu Apr 02, 2015 6:58 pm
HA HA straight on ebay NOS and all that
joe swoonara
Re: Bodged
Postby xenia1 » Thu Apr 02, 2015 8:47 pm
There are bodges/quick fixes some permanent some temporary same with cars. If that doesnt leak and works ok ,obviously not the correct way to do it but i'd call that fixed, a bodge would be P40 or JB weld and the like. Most likely done at some point in its life at a time when no used parts were available.
xenia1
Re: Bodged
Postby modster79 » Fri Apr 03, 2015 7:47 am
:D
modster79
