Pathfinder rubber mount
Postby Wilson » Mon Mar 23, 2015 5:00 pm
Just received a rubber mount for a lucas spot light,this is to go on a li series 2,my question is are there two types of mounts s2 & s3.as it looks like I will have to cut a lot off to make it fit my leg shields,is this the normal thing to do,please help. :(
Wilson
Re: Pathfinder rubber mount
Postby Angry Bloke » Mon Mar 23, 2015 5:43 pm
Unfortunately there is only one type available and you will need to cut them for an S2
Its a right pig of a job and the best advice I can give is for you to make a template with a cardboard tube and go from there. ;)
Angry Bloke
Postby Wilson » Mon Mar 23, 2015 6:11 pm
Cheers angry bloke I thought so. :cry:
Wilson
Postby MK Monty » Mon Mar 23, 2015 9:14 pm
60 grit flap wheel in an angle grinder, you will come out like a black man. Offer it up turning it round to get the face as vertical as possible . Trim and try. It will squash up when you use the bolt through. I dished out the face a tad as well.
MK Monty
Users browsing this forum: Google [Bot] and 8 guests
