Suggestions for Digital Speedos for Series 2 that fits......
Postby Donnie » Tue Feb 10, 2015 7:44 pm
.... in the actual headset.
So, leading on from the Acewell speedo thread here viewtopic.php?f=10&t=2480 I thought it's worth exploring if there are others out there that will fit?
So, by that I mean one that doesnt involve cutting the headset etc like a vapor one would.
Additionally I want one that is fully digital, ie not like the sip ones that still need a cable for the actual speed.
Anyone know of any (other than the acewell) that can be used?
Donnie
Re: Suggestions for Digital Speedos for Series 2 that fits..
Postby Donnie » Tue Feb 10, 2015 7:55 pm
Found one through google thats actually on MBs site, ie http://www.lambrettaspares.com/spares/s ... mb008.html which is a koso thats too small but of course MB do a converter ring :-)
Donnie
Postby MK Monty » Tue Feb 10, 2015 11:06 pm
Its the size and how much you can cut off the rear to clear the pulleys. Speedhut have a good range of GPS ones in several diameters though the smaller ones dont have trip miles travelled etc.
http://www.ebay.com/itm/Speedhut-2-1-16 ... 1308765316
No they will not work on an AC system
MK Monty
Postby mickyb » Tue Feb 10, 2015 11:20 pm
I fitted an Acewell to my series 2 by putting a 3/8 inch spacer between headset and speedo, didn't need to cut it and everything fits under headset
mickyb
Postby Donnie » Tue Feb 10, 2015 11:59 pm
MK Monty wrote:Its the size and how much you can cut off the rear to clear the pulleys. Speedhut have a good range of GPS ones in several diameters though the smaller ones dont have trip miles travelled etc.
Ill check that link out mate, thanks. And Im running Wassell DC so not a problem.
Donnie
mickyb wrote:I fitted an Acewell to my series 2 by putting a 3/8 inch spacer between headset and speedo, didn't need to cut it and everything fits under headset
got a piccie?
Donnie
Postby Donnie » Wed Feb 11, 2015 12:01 am
Just looked and its not waterproof :-/
Donnie
Postby Mel K » Wed Feb 11, 2015 8:10 am
You can waterproof the Speedhut one with clear silicone , I done mine, years ago and it's still going strong, wipe any excess whilst still wet with silicone cleaning wipes. You need to get it in around the edge of the glass where it meets the bezel .
Also , you'd never know and can't see the silicone .
Mel K
Postby Donnie » Wed Feb 11, 2015 11:32 am
hmmm I do like that speedwell one i have to admit as i like the fact it looks like an analogue one, even though its the most expensive of the 3.
Im thinking though the fact that both the acewell and the koso both have other functions and dont need extra waterproofing might edge it to the number 3 spot currently.
Donnie
Users browsing this forum: Bing [Bot] and 8 guests
