Expansion pipe
Expansion pipe
Postby stonerosesmod » Wed Oct 29, 2014 3:10 pm
Which would be the better all round pipe for a mugello 200 out of the Taffspeed replica or Franspeed supertourer? Had a JL3 but fancied something different.
stonerosesmod
Re: Expansion pipe
Postby Cgt75b » Wed Oct 29, 2014 3:48 pm
Have you not considered the Ads 3 Chiselspeed pipe ?
Re: Expansion pipe
Postby stonerosesmod » Thu Oct 30, 2014 1:41 pm
Gone for the supertourer,read some good reviews so fingers crossed!
stonerosesmod
Re: Expansion pipe
Postby stonerosesmod » Tue Nov 04, 2014 9:52 pm
Well,fun and games this week! Had to file the franspeed stub to get it to fit past the barrel fin and file the weld down so the kickstart side stub nut fitted properly.Then filed the chaincase bracket to stop the exhaust pushing down on the kickstart.All sorted then put the end can on and it was rubbing hard on the panel handle! luckily had some spare nylon spacers to hold it away without stressing the exhaust too much but all together now and sounding good.Dont know if its the mugello exhaust flange or my bad luck :? Just need some time to try it out now :x
stonerosesmod
Re: Expansion pipe
Postby rexton270s » Fri Feb 06, 2015 4:55 pm
my franspeed and mugello fitted like a glove! am normally unlucky....if i fell into a bucket of tits i would come out sucking my thumb!!
rexton270s
Re: Expansion pipe
Postby Toddy » Fri Feb 06, 2015 5:15 pm
Bit of info here re muggello / franspeed fitting
http://scooterotica.org/forum/viewtopic ... ed+exhaust
Re: Expansion pipe
Postby Train driver » Sat Feb 14, 2015 5:19 pm
Train driver
