Rear Brake O Ring
Rear Brake O Ring
Postby col1968 » Mon Jun 09, 2014 5:25 am
Hi, could someone help me please, i have stripped down my rear hub.When putting back together, i am not sure where the rear brake cam o ring goes.Any help would be appreciated.Thanks Col
col1968
Re: Rear Brake O Ring
Postby Toddy » Mon Jun 09, 2014 6:14 am
There you go
http://www.scooterrestorations.com/lamb ... res-tubes/" onclick="window.open(this.href);return false;
Postby col1968 » Mon Jun 09, 2014 7:58 pm
Thanks Toddy
col1968
Postby denisiw » Fri Jun 13, 2014 9:43 am
I've sometimes had difficulty getting the circlip on the end of the shaft if this is 'O' ring is fitted.
Something I've noticed about that illustration is that it shows a washer/shim under the circlip, but it is not itemised. It was used on the Li Series 1 but was omitted when the Series 2 came out and thereafter, Innocenti never bothered to remove it from the diagram.
Denis
denisiw
Postby col1968 » Mon Jun 16, 2014 5:14 am
Thanks Denis, i have noticed this washer/shim too. Cheers Col
col1968
Users browsing this forum: Google [Bot] and 20 guests
