Scooterlam wrote:^^^
Why?
coaster wrote:Scooterlam wrote:^^^
Why?
I agree, fitting a read valve on it's own won't give more speed. In fact you will lose some performance unless mods to piston and ports are undertaken. On the other hand, it will allow you to run with more radical port timings by managing the spit back associated with overlapping port timings.
.Reed valves are basic and can enhance performance simply because they keep the fuel in the engine. Simply stated, a reed valve is a one-way check valve that allows fuel to flow into the engine and then closes, making sure the fuel charge doesn’t spit back. The reed valve works off the engine’s internal pressure changes. When atmospheric pressure in the 2-stroke engine’s crankcase is low, the valve opens and allows fuel to flow in. During compression of the charge the reed valve is closed, keeping the charge in to be combusted.
That is an oversimplification, but it is fundamentally how the system works. The result is improved low end and generally an increase in performance
. [/img][/quote]Reed valves are basic and can enhance performance simply because they keep the fuel in the engine. Simply stated, a reed valve is a one-way check valve that allows fuel to flow into the engine and then closes, making sure the fuel charge doesn’t spit back. The reed valve works off the engine’s internal pressure changes. When atmospheric pressure in the 2-stroke engine’s crankcase is low, the valve opens and allows fuel to flow in. During compression of the charge the reed valve is closed, keeping the charge in to be combusted.
dickie wrote:Is a finger port a boost port?
I'm thinking of adding a reed valve with boost port and piston cut-outs, but am slightly concerned that I'll sacrifice top end.
Will the piston cut-outs and boost port compensate for flow restriction caused by the reed?
coaster wrote:
Re the finger port, I cut one on an ally 225 cylinder and found it quite easy to break through the outside wall
So you mean that you wrecked the barrel?
