drivera wrote:Just measured one , 36mm of shank and 15mm of thread
grumpar wrote:Thanks mines 51mm 36 and 15 more problems these forks are really starting to piss me off now![]()
i will probably have to have some made
dickie wrote:grumpar wrote:Thanks mines 51mm 36 and 15 more problems these forks are really starting to piss me off now![]()
Eh? I don't get it. You have 1mm more than me and 5mm more thread and mine were fine in my forks.
What do you mean by "lock washers"? There should be one star washer per link and a plain washer on the right side only as the cable guide does the job on the left leg.
drivera wrote:Have you tried tightening them to the correct torque to see if the fork boot compresses a bit , they are only a 3 sided box section so can compress a tad ?
dave411 wrote:Is the tensile strenght of the stainless bolt the same,or greater,than the original?
HxPaul wrote:If you use longer bolts make sure that the tyre valve doesn't hit the end of the bolt when the wheel is rotated.
Users browsing this forum: martyn dwane and 20 guests
