Li chain case to Gp engine
Postby Meds » Sun Dec 21, 2014 2:47 pm
Are there any pitfalls or changes that need to be made when fitting an LI chain case to a GP engine with a standard GP end plate, other than removing the Li Kickstart ramp?
Meds
Re: Li chain case to Gp engine
Postby berniek » Sun Dec 21, 2014 4:45 pm
Change the clutch pressure plate to the li type also so that it marries up with the li type pushrod / cam.
berniek
Postby rossclark » Sun Dec 21, 2014 11:31 pm
I switched mine back to a GP casing recently and could not get the clutch arm / rod out of th Eli casing to work on the go one. I ended up replacing the whole thing with GP parts and it was fine after that.
Users browsing this forum: No registered users and 15 guests
