nastro azzurro wrote:I wouldn’t be happy with any amount of play. I’d be chasing the issue until I’d eliminated any play.
Did you replace / check each component one at a time?
bookertmgs1 wrote:
can't get rid if it - I've made my peace with it now.
hullygully wrote:try an af's uprated rear hub bearing, with just the layshaft in the brg (no g/box or endplate) there ain't no movement @ all
bookertmgs1 wrote:I
Think its worth clarifying the "play" - on mine - its only the slightest "rock" when the rim / tyre is fitted. Cant feel anything when just the hub is fitted
bookertmgs1 wrote:I have lapped the rear hub cone to the hub with course and then fine grinding paste - but havent then checked fit with engineers blue after that.
Thats probably a winter job after the next couple of rallies.
confident that the replacement parts I've fitted are of decent quality - MB etc - the only questionable part would be the Scootopia Hub. I've read / seen comments about variable quality - but the only alternative would be a UNI hub - have seen similar quality issues with those too.
Users browsing this forum: Baidu [Spider] and 217 guests
