Horn cover strips
Horn cover strips
Postby Peterp » Thu Feb 05, 2026 3:56 pm
Hello all,
I’m needing to replace the above horn strips on my TV175 series 3 because they are too short. I’ve recently bought this but it has a few daft issues like this, it looks “pants” so they’ve got to go.
Any suggestions where is best to get the right length ones or ones that I can cut to correct length p.
Cheers, Pete
Peterp
Re: Horn cover strips
Postby Adam_Winstone » Fri Feb 06, 2026 12:15 am
A number of years back I sourced 'longer than standard' strips from Cambridge Lambretta, which I then cut to length. They may / may not still do them but your best bet is to give them a call as they might not be listed on the website, if they do still have them.
Good luck.
Postby gaz_powell » Fri Feb 06, 2026 9:50 pm
The MB ones are best I've used, long to cut to size and different shape and material that grips the horncasting really well
Postby Peterp » Sat Feb 07, 2026 2:08 pm
Thanks both
Peterp
Users browsing this forum: Google [Bot] and 66 guests
