Pompeydave wrote:No I’ve just got the standard piston which is knackered. Didn’t realise GOL were Indian. Trying to avoid Indian or the TS185 as I want to keep it as standard as possible.
Fast n Furious wrote:The transfer port apertures are located about 25mm offset from the piston centre line. So no problem here.
The top of the inlet port is about 11.5mm down from the bottom of the exhaust port. With the right thickness aluminium base packer, the 2nd ring shouldn't fall into the inlet port.
IMD pistons make a cast version of the TS185 and typically cost less than £50 on fleabay. These pistons are ok although the rings are known to be a bit soft but that could just be because they get run on 2% oil istead of 4%.
Recommend 3 thou piston to bore clearance and 10 thou ring gap.
Users browsing this forum: Google [Bot] and 21 guests
