Boyesen Reeds
Re: Boyesen Reeds
Postby ULC Soulagent » Fri Nov 08, 2024 5:10 pm
gaz_powell wrote:Stops it is... That was my choice.
Ive got 2 blocks without the stops just the plates, as ive never used them always favored the stops.
Its a next year over haul of the GP motor... New clutch set up, rings, reeds etc.
Only put stops in on the boost port side as that’s the way Harry set up my ts1 ;)
ULC Soulagent
Re: Boyesen Reeds
Postby gaz_powell » Fri Nov 08, 2024 6:28 pm
Cheers Shane
Re: Boyesen Reeds
Postby gaz_powell » Fri Aug 08, 2025 7:06 pm
Ive finally set up a AF block with the Boyeson two stage reeds and fitted stops.
HB told me to fit the stops and ensure a 9mm lift... Which is all fine, he said to arch the boost port side stop...cant get in touch with HB, anyone had this done??
Re: Boyesen Reeds
Postby hullygully » Mon Aug 11, 2025 9:46 am
does he mean you can bend the stops out to suit your inlet? :?
Re: Boyesen Reeds
Postby gaz_powell » Tue Aug 12, 2025 10:37 pm
Told me to measure from top of reed to stop with a steel rule.
The measurement was bang on 9mm on both sides.
I think he was saying take the edges off the stop on boost port side to make it more arched but still maintain the stop at 9mm so as not to allow reeds to push to far back. He said definately fit the stops
Users browsing this forum: Google [Bot] and 4 guests
