Thanks for your help
Fast n Furious wrote:Downsizing the front sprocket will make it more difficult to kick over especially if you have a light flywheel.
Change it back to an 18 and see what difference it makes and go from there.
Storkfoot wrote:17.8 & 5.4 = 23.2cc giving a corrected compression ratio of 10.63 and an uncorrected of 6.55.
Storkfoot wrote:Minor detail![]()
dickie wrote:You could change to a gp200 box and use 20/47 sprockets to get a similar final drive.
If you want to keep the exhaust characteristic.
Fast n Furious wrote:TBH Paul,
I think I would have the same issue with my TS1 if I was lucky enough to only weigh in at 11 stone!
What kickstart pedal are you using?
The short GP style ones won't help you here.
