Fast n Furious wrote:If your oil seal plate is an Indian aluminium one, then I would advise ditching it and replacing it with an Italian steel one.
Storkfoot wrote:Before you go out again, just check that the choke is working properly since your rebuild.
Is it possible that, before your problems, you had overly rich jetting that was masking an air leak? An air leak test (at least the ones I do) are completed in the absence of the exhaust and carburettor so you could have still had had an air leak at exhaust and inlet manifolds. Now that you have partially rebuilt the engine, you have fixed the air leak and your jetting is now too rich![]()
Or, did you replace the hallite washer and, if you did, was it sealing between the plate and bearing?
Just a few thoughts
nsaints wrote:Just need to talk this through
I’m attempting to figure out where a considerable amount of my gearbox oil has vanished in the last 1,000 miles or so
I’m trying out FnF’s ballon diagnosis of a failed main oil seal for the first time.
Running the scoot up to temperature the ballon inflates as the air temperature in the gearbox side increases
It’s quite difficult to see the pulsing due to the normal vibration of the engine
Should the pulsing be really obvious if the seal has failed?
Secondly reving the bike from tickover where the ballon has inflated and the ballon immediately deflates
I’m thinking this deflation indicates air being sucked in past the oil seal - does this logic seem sound?
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 22 guests
