L111amo wrote:Whatever you do don’t fit a mb bigger cam, waste of time, fitted one & took me an age to try & get a good brake, binned it & fitted standard size one & perfect brake straight away
Storkfoot wrote:Have you got a hub removing tool like these?
https://jbfab.co.uk/product/lambretta-r ... oval-tool/
https://www.lambretta.co.uk/product_inf ... cts_id=281
You also need a way of keeping the hub still whilst you undo the main nut. Most of us have an old half rim with a “V” shape of metal welded on, or a bit of box section welded on. Anything that’ll jam against the engine casing and stop the hub turning.
If you are going to CamLam anyway, I’d ask them if they have a proper skimming tool for brake shoes.
coaster wrote:I've got a rear wheel locking device if you want to borrow it and also have an old rim if you want to make your own
Also check out The Steel Weazle (Steve Richards) on Face Book, he did a video on sorting the front brake which has relevance to the rear as well/
Warkton Tornado No.1 wrote:Normally, however bad the brake, there will be enough of a hold with the foot brake virtually stood upon, to undo the 27 mm nut (normal RH thread) single-handedly with a torque wrench/breaker bar, almost like an imaginary game of Twister. Or - wait for this! - if the cable has been disconnected, a RING SPANNER can be utilised on the brake cam lever to hold the drum![]()
If you have access to a 1/2” square impact driver - & I bet you do - that will also rattle the nut off.
Covboy wrote:Heres a trick i always use when adjusting the rear brake cable:-
get a large thick cable tie and wrap it around the rear brake arm and casing lug
pull/ tighten it up as much as possible so that the rear brake is fully on
then at the pedal end pull the cable taught and tighetn up the clamp assembly
cut off the cable tie and adjust the final cable tightness/ brake bite with the 10mm nut on the end of the cable
hope that make sense -
Warkton Tornado No.1 wrote:All joshing aside, if using the most common type of hub puller that utilises the three M7 holes, try to ensure that there is full thread engagement prior to use. In other words, M7 fasteners that are too long - but equal in length - will be a much safer option than fixings that are too short.
It’s worth running an M7 tap down the three holes to make sure all of the available threads are utilised.
Once the puller is in place & the centre bolt slack removed, a tentative knock with a soft faced mallet will often shock the hub off.
Re-assembly means scrupulously clean & as the taper cone is the driving element, I always apply a smear of Copaslip inside & out, ensuring the cone split is in line with a layshaft spline element, not a groove.
Genuine OEM hubs & matching cones - & no doubt, some good patterns - were always best lapped together with grinding paste prior to fit. Beware of cones that are not hard enough! Over the years, I have bought replacement cones to suit the excellent Serveta hubs but none have ever been of sufficient hardness. The consequences are that the cone shows evidence marks of the spline & the hub loses it’s fit. Even the cones acquired from Scooter Restorations are soft & I am surprised that nobody else has ever mentioned it on this Forum, or - should I say - I cannot ever recall it being flagged up
Warkton Tornado No.1 wrote:Oops! From the images added, you clearly have sorted out certain of the issues involved with hub removal already![]()
I couldn’t help noticing the earth lead on the flywheel cover. You may never encounter any problems as it is, but there will be many readers that have chased their tails with intermittent electrical gremlins. Chrome or stainless fan covers are not the best electrical conductors, but, no doubt, that arrangement was inherited with the bike.
Personally, an even heavier duty earth strap, such as a car type, affixed to a dedicated tapped hole in the flange of the magneto housing, or even from the stator itself, eliminates any concerns about a good earth twixt frame & engine. Consider it cheap insurance
Users browsing this forum: Bing [Bot] and 15 guests
