gp200ts1 wrote:I use a wide blade flat screwdriver. push it into the rubber about 5-10mm up from the fork boot surface. when you push in it should push the rubber out of the location lip on the forks.
Stop Removal by KTM Marky, on FlickrLambrettaMarky wrote:I did this recently:Stop Removal by KTM Marky, on Flickr
You need to get the spring compressed and as said above just go at the rubber with a good sized flat blade screwdriver. Just need to get it out of the channel it sits in to pop it out. Don't worry about destroying the rubber, but be a little careful not to destroy the channel that's spot welded (I presume) to the main fork.
Getting it all back together is equally entertaining!
nickw wrote:Whilst I think doing this with a spanner is good, for those that struggle with this, Keith Newman has made some of these which I think have been made by others.
https://k2customs.co.uk/products/fork-s ... essor-tool
Fast n Furious wrote:Hmm. Spanner and ratchet strap......Russian Roulette springs to mind!![]()
LambrettaMarky wrote:I can assure you I made sure it wasn't going to move and if by any odd chance it did I was out of the way. It takes a few seconds to remove the rubbers then the spanner came off in a controlled manner.
No drama if you keep out of the firing line & do it quickly..
Warkton Tornado No.1 wrote:LambrettaMarky wrote:I can assure you I made sure it wasn't going to move and if by any odd chance it did I was out of the way. It takes a few seconds to remove the rubbers then the spanner came off in a controlled manner.
I get that, but the task can be undertaken with just a ratchet strap![]()
Even with the forks in situ, the strap can be wrapped around the forks near the crown with the other hook positioned anywhere stable. TBH I doubt the spanner would fail, it’s just that I can see no benefit in using it. If the ratchet hooks are too large to fit the the link slots, the strap itself will fit with the hook around the strap itself…..
LambrettaMarky wrote:Pleasure mate - all sorted now?
Users browsing this forum: Google [Bot] and 20 guests
