Circlip pliers
Circlip pliers
Postby nsaints » Fri Nov 01, 2024 9:36 am
Every time I use circlip pliers I struggle, hating them, promising myself a new and better set.
The problem is a decent set is approaching £100
I then convince myself I don’t use them enough to warrant spending the money
This cycle has been repeating itself for years and years
Am I the only one..
Anyone got a recommendation to convince me to end this torture?
nsaints
Re: Circlip pliers
Postby Storkfoot » Fri Nov 01, 2024 10:12 am
I am still using the Lang ones referred to in the thread below. I’d give them 6/10 whereas all the other ones I have used over the years have never got above about 3/10.
viewtopic.php?f=22&t=14099&p=128537&hilit=Pliers#p128537
Re: Circlip pliers
Postby nickw » Fri Nov 01, 2024 10:44 am
I had the same problem with the damn things. I bought an expensive set and no better. I think I have about 4 or 5 different sets now and none appear any better then the other. A poor workman blames his tools keeps ringing in my ears when removing circlips lol
nickw
Re: Circlip pliers
Postby LambrettaMarky » Fri Nov 01, 2024 11:40 am
I have a set with three different actual plier ends which can be removed & reversed to suit internal/external etc. OK for light ish stuff and served me well for many years..
Not exactly this, but close enough:
https://www.machinemart.co.uk/p/laser-5 ... l-circlip/
LambrettaMarky
Re: Circlip pliers
Postby nsaints » Fri Nov 01, 2024 12:30 pm
Thanks,
Looks like I have a pair of 35 year old lang circlip pliers re-branded as RS components
Think I'll buy some replacement tips in an attempt to reduce my frustrations :roll:
nsaints
Re: Circlip pliers
Postby Covboy » Fri Nov 01, 2024 2:23 pm
How many times have we been on our hands and knees in the shed looking for that circlip that has pinged off, especially the little one on the gear control arm :roll:
Re: Circlip pliers
Postby roli150lam » Fri Nov 01, 2024 2:35 pm
i have a set of lang circlip pliers,pain changing those tips tho.
i also have decent pairs bought from auto jumbles.
roli150lam
Re: Circlip pliers
Postby Adam_Winstone » Fri Nov 01, 2024 2:49 pm
I have at least 4 pairs, one larger for mag side, 3 for piston and other smallies. The larger ones are fine but the smaller ones tend to wear / round off and so become rubbish!
Re: Circlip pliers
Postby bookertmgs1 » Fri Nov 01, 2024 2:55 pm
I bought some Laser ones from Halfords / Ebay - 4 differet sets - internal / external / angled / straight. They were about £10 for each one
They are ok - but as others have said above - I've found the tips to be a tad too big and therefore difficult for the smaller circlips. they work really well on the disc brake / mag housing circlips
Having bitten the bullet once - I'm resigned to struggling as I'm not investing again
bookertmgs1
Re: Circlip pliers
Postby nsaints » Fri Nov 01, 2024 5:23 pm
I couldn't bring myself to buy new tips for my ageing universal do it all pliers
Instead I've bought some Knipex pliers specific to the size of the disc brake actuator circlip
Not too bad @ £20
I only hope they live up to expectation
nsaints
Re: Circlip pliers
Postby dickie » Sat Nov 02, 2024 9:29 pm
I've had a pair of these for years and they've never failed.
You can buy replacement tips too.
Not as convenient to swap tips like those commonly available ones, but much sturdier and nicer to use.
https://uk.rs-online.com/web/p/pliers/5417267
Re: Circlip pliers
Postby Cgt75b » Sun Nov 03, 2024 9:41 am
I’ve found these to be excellent + great value also.
https://www.machinemart.co.uk/p/cht170- ... ip-pliers/
Re: Circlip pliers
Postby L111amo » Sun Nov 03, 2024 9:23 pm
I’m an ex ford tech, (only finished 2 years ago) early I must say, I’ve got several snap on sets , all still really good& lifetime guarantee
L111amo
