AF Clubman Downpipe/Box Leak
Postby Granty » Sat Oct 26, 2024 7:09 pm
Rebuilding after a sieze and i can't seem to seal the connection between the U bend and exhaust box. The camp just will not seal 100%, even with some 3 bond and i can see small leak of exhaust fumes. Is this dangerous or will it effect the jetting and do i need to ensure a 100% seal? Thanks for the input. -- G.
Granty
Re: AF Clubman Downpipe/Box Leak
Postby Storkfoot » Sat Oct 26, 2024 8:53 pm
Yes, you do need to fix it. Your exhaust is not functioning as it should. It sounds like when the silencer is fitted, it is pulling at the u-bend. Usually, the remedy is to take a cylindrical file or dremel to where the silencer fits to the engine casing.
What cylinder do you have?
Postby Granty » Sat Oct 26, 2024 10:01 pm
Storkfoot wrote:Yes, you do need to fix it. Your exhaust is not functioning as it should. It sounds like when the silencer is fitted, it is pulling at the u-bend. Usually, the remedy is to take a cylindrical file or dremel to where the silencer fits to the engine casing.
Hi -- it's a standard 200 barrel .... i'll get into it and fettle a bit -- G
Granty
Postby L111amo » Sun Oct 27, 2024 8:09 pm
I don’t see where it fits the body of the block would cause this, ?
L111amo
Postby Storkfoot » Sun Oct 27, 2024 9:12 pm
L111amo wrote:I don’t see where it fits the body of the block would cause this, ?
I am not saying that the engine casing is at fault.
If either the silencer or the ubend, or both, have not been made to correct tolerances, they won’t marry together correctly. You can’t adjust the ubend, without great difficulty, but you can adjust the silencer fit to the engine casing. It’s not ideal but you haven’t got much choice, other than sending it back.
I have an AF 42mm Clubman fitted to a standard Jet 200 barrel. It only needed the slightest of adjustment to the silencer to be a very good fit. But, that was probably more by luck than by design.
Postby L111amo » Mon Oct 28, 2024 1:51 am
Doesn’t say it’s a new exhaust
L111amo
Postby Storkfoot » Mon Oct 28, 2024 9:20 am
… You can’t adjust the ubend, without great difficulty, but you can adjust the silencer fit to the engine casing. It’s not ideal but you haven’t got much choice, other than sending it back….
On reflection, if you assess that the silencer would need major “adjustment,” you may need to look at adjusting the ubend. If you adjust the slots where it attaches to the cylinder, you need to be very careful that you don’t do too much so that you then get an air leak there. If you bend the pipe slightly, you need a means to get the bend to red hot.
Good luck with whatever you decide.
Postby L111amo » Mon Oct 28, 2024 11:53 am
Generally some decent exhaust paste should fill slight gaps at the joint, just let it go off before starting it up or it will blow out
L111amo
Postby Granty » Tue Oct 29, 2024 5:57 pm
L111amo wrote:Generally some decent exhaust paste should fill slight gaps at the joint, just let it go off before starting it up or it will blow out
Thanks for all the input guys, it's not a new pipe, it's a bend & box off another bike. I'll try a blend of filing out the tailpipe hole and the chain casing hole to make it a slip on/in fit and get the paste into it & see what happens. If all fails then a new pipe. Main question was does this need fixed and the resounding answer is yes it does, so onwards.
Thanks again & I'll keep you posted - G
Granty
