Heavy luggage takes its toll
Postby Storkfoot » Sun Oct 06, 2024 4:03 pm
Re: Heavy luggage takes its toll
Postby B1gD0gu3 » Sun Oct 06, 2024 10:33 pm
Jesus! what was in your luggage? Lead ingots? :shock:
B1gD0gu3
Postby Storkfoot » Mon Oct 07, 2024 8:06 am
B1gD0gu3 wrote:Jesus! what was in your luggage? Lead ingots? :shock:
Other than the occasional local delivery of gold bullion, just rally gear. :P
It first started going like this in 2015 on the way back from Bannockburn. I lost a nut off the rack on the way home. Since then, I have just touched up the paintwork every now and then when really I should have sorted it out :roll:
Postby Rich Oswald » Mon Oct 07, 2024 8:25 am
Been there, done that!
Postby Storkfoot » Mon Oct 07, 2024 12:46 pm
Rich Oswald wrote:Been there, done that!
How did you get it fixed, Rich?
Postby Rich Oswald » Mon Oct 07, 2024 3:45 pm
Mike Phoenix sorted it,
Postby Storkfoot » Mon Oct 07, 2024 7:11 pm
Thanks, Rich. As I suspected, the spot welded support underneath will need knocking out first.
Postby Storkfoot » Tue Nov 19, 2024 6:30 pm
I have stripped the scooter down to just the frame and legshields ready to get this fixed. I also took a minute to drill out the spot welds. The vibrations from the drill brought a rather large pile of rust out from the middle of the tube :roll:
Oh, and I also have another fracture needing welding
Postby LambrettaMarky » Wed Nov 20, 2024 4:49 pm
Some work going on there Paul.
I used this on my '65 TR4a to protect the chassis: https://www.theultimatefinish.co.uk/pro ... x-s50.aspx
Came with a super long lance to get it into hard to reach areas & maybe an idea to treat the inside of our tubular chassis?
Think I'll get some more and coat the inside of mine.
LambrettaMarky
Postby Storkfoot » Wed Nov 20, 2024 5:47 pm
LambrettaMarky wrote:Some work going on there Paul.
On another GP that I had, I pumped waxoyl into the frame. I was thinking of doing the same with this but, really, you need a nice hot sunny day so that, before the wax sets, you can twist and turn the frame around.
Postby Rich Oswald » Thu Nov 21, 2024 5:00 pm
Storkfoot wrote:I have stripped the scooter down to just the frame and legshields ready to get this fixed. I also took a minute to drill out the spot welds. The vibrations from the drill brought a rather large pile of rust out from the middle of the tube :roll:
Just like mine was Paul before it went to Mike Phoenix.
Postby Storkfoot » Thu Dec 12, 2024 10:20 pm
I now need to decide how to try and stabilise the rust in the frame before the frame goes for the repairs to be painted in the new year.
Postby Rich Oswald » Thu Dec 12, 2024 11:07 pm
Looks good that Paul.
Postby gaz_powell » Fri Dec 20, 2024 12:37 pm
Who did that work Paul?
Postby Storkfoot » Fri Dec 20, 2024 2:23 pm
A lad local to me in Wallasey, Gaz. I have used him for years. He’s not a scooterist.
Postby gaz_powell » Fri Dec 20, 2024 6:40 pm
Nice to have someone on hand...
