Hi folks
Does anyone have experience with the high flow air filters through the standard airbox, any feedback please?
Good or bad
hullygully wrote:a breathe sweet filter, airbox drilled out, Armadillo air hose, I have used a sh2/22 bored out to 25mm thru this system on my TV, up jetted to suit on a Mick Abbey tuned 175 & on a Gori 200, now I use a 26mm PHBH thru' this system with a RT200 & have done numerous rallies with this set up, uncluding Euros & 4 Nations
Warkton Tornado No.1 wrote:hullygully wrote:a breathe sweet filter, airbox drilled out, Armadillo air hose, I have used a sh2/22 bored out to 25mm thru this system on my TV, up jetted to suit on a Mick Abbey tuned 175 & on a Gori 200, now I use a 26mm PHBH thru' this system with a RT200 & have done numerous rallies with this set up, uncluding Euros & 4 Nations
If I understand this properly, you have a Breathesweet filter sitting in place of the OEM cartridge in an OEM air-filter box - albeit ‘drilled out’
So, is the filter somehow ‘sealed’ in the air-filter box to only take in fresh - body scoop - air & additional under-panel-air via the holes added?
hullygully wrote:I'm presuming mines a 'breathe sweet' as I bought & fitted it 14yrs ago, same shape as std one but wire framed & different filter material
Users browsing this forum: Bing [Bot] and 25 guests
