Choke thread size on a SH20 carb?
Postby Scooterslag » Thu Aug 29, 2024 5:01 pm
as above- thanks Paul
Re: Choke thread size on a SH20 carb?
Postby Knowledge » Tue Sep 03, 2024 11:39 am
I don't know, but why do you need to know?
This area is prone to problems/damage and there are some work-arounds depending on the issue.
Postby Scooterslag » Tue Sep 03, 2024 2:52 pm
Knowledge wrote:I don't know, but why do you need to know?
Yes Martin, I didn't screw in the choke unit properly and caused slight damage to the threads. Wanted to see if I could tidy it up a bit. Cheers Paul
Postby Knowledge » Tue Sep 03, 2024 6:54 pm
There is stuff about this on page 168 of Sticky's green book. He uses a hammer to give the thread a bit more grip.
I think the thread is already cut a few millimetres deeper than is required and I have seen a work-around where the top few millimetresof the boss on the carb are carefully hack-sawn off to present fresh, undamaged thread for the choke to screw into.
Postby Scooterslag » Tue Sep 03, 2024 8:41 pm
Knowledge wrote:There is stuff about this on page 168 of Sticky's green book. He uses a hammer to give the thread a bit more grip.
That second solution sounds interesting, thanks for the info Martin, cheers Paul :)
Postby Fast n Furious » Thu Sep 05, 2024 8:16 pm
It's M8 x 1.00
Postby Scooterslag » Thu Sep 05, 2024 11:46 pm
Fast n Furious wrote:It's M8 x 1.00
Thanks F&F - cheers Paul ;)
Return to Carburettors
