Fast n Furious wrote:These disc brakes are somewhat challenged by their design.
The amount of force that the actuator can apply to the moving disc pad is proportional to the reverse force applied in the opposite direction onto the retention circlip, which will readily deflect if pressed beyond a certain point.
Saying that........ I recently did a hydraulic conversion to one of these brakes and even though I could get it so hot and smoking under testing that it would burn the paint on the castings the braking effeciency was really no better than before, which was dissapointing.
I remain optomistic that it can be improved, but have shelved it for now.
Need one of those Eurica moments.
dickie wrote:Fast n Furious wrote:These disc brakes are somewhat challenged by their design.
That's kind of hard to get your head around because the job of a brake is to turn kinetic energy into heat energy and it sounds like it's doing exactly that, and pretty well too.
Maybe it generated a lot of heat but over a longer time period than you'd want? Maybe it generated no more heat than a drum brake but poor ventilation and/or high ambient conditions stopped it from cooling sufficiently?
I suspect I'm wandering slightly off topic here.
dickie wrote:WT1, you've reminded me of another 'thing' that I found with remade discs.
The anti rattle clip doesn't need removing, but in the 2 that I've worked on, I had to bend the clip to a smaller diameter or it gripped the pins too hard. I just squashed it in a vice until I was happy. Made a big difference. Before I did this, I could barely slide the disc on the pins; easy after, but still retained its anti-rattle feature.
Fast n Furious wrote:dickie wrote:WT1, you've reminded me of another 'thing' that I found with remade discs.
Another way to trim the antirattle clip is by relieving the clips grip slightly using a dremmel through the 3 holes. If you over do it,then you can just tap the clip around into a new position and start again.![]()
I plan do do some cost effective experimentation with the pads. The current plan is to use some old stock pads from various cars that I have by cutting then up with a 42mm hole saw and then machine them up to finished size in the lathe.
Not sure when I can get around to this but I'll report back when I do.
Users browsing this forum: Google [Bot] and 4 guests
