Front Damper Repairs
Postby Madstadblues » Tue Dec 02, 2014 6:49 pm
Has anybody any experience of repairing the SCM dampers from a TVS3 ? Thanks.
Madstadblues
Re: Front Damper Repairs
Postby xenia1 » Mon Dec 08, 2014 8:04 pm
Madstadblues wrote:Has anybody any experience of repairing the SCM dampers from a TVS3 ? Thanks.
If you mean the steel shroud at the top then yes. Carefully remove the spot welds with a dremel and obtain some 25mm steel tubing from B&Q or the like and very carefully tack weld the new section into place and flat back. The bushes can be replaced using reinforced rubber tube using the original steel inserts.
Hope this is of some use to you,
Andy.
xenia1
Postby Madstadblues » Wed Dec 10, 2014 12:56 pm
Thanks, have you any examples of where you have done this ?
Cheers MSB
Madstadblues
Postby xenia1 » Fri Dec 12, 2014 6:57 am
I dont have any pictures unfortunately but did this on a pair of Tv1 front shocks and once painted looked as good as new. Subsequently found some n.o.s ones but would have been happy to have fitted the repaired ones. As long as a little care is taken removing the old steel shroud and you have someone skillful with a m.i.g welder able to carefully tack the new ones in place.
xenia1
Users browsing this forum: No registered users and 24 guests
