Unstamped engine casing
Postby Triffid » Sat Jun 15, 2024 3:23 pm
Excuse my ignorance but I have an (Indian) unstamped engine casing i.e there are no stamped engine numbers in the usual position. I was hoping to use this as the basis for a engine rebuild but then have thoughts regarding the law and using engines without numbers in a registered scooter. If any adults are in the room, perhaps they could advise what the situation is regarding the DVLA etc. Thanking peeps in advance
Triffid
Re: Unstamped engine casing
Postby gizmo » Sat Jun 15, 2024 4:50 pm
DVLA are not concerned with engine numbers. I have had V5's with no engine number declared as is one I have at present which was recently registered without one. Obviously tell your insurance company what cc you put in and you should really inform DVLA if you put a larger engine in than your scooter is registered as
gizmo
Postby Rich Oswald » Sat Jun 15, 2024 8:22 pm
As Gizmo has said, DVLA couldn't care less if there is an engine number on or not. I have registered scooters with blank casings.
Richard Oswald
LCGB Registrar
Postby Triffid » Sun Jun 16, 2024 9:29 am
Thank you, guys - that is reassuring :D
Triffid
