by gizmo » Sat Mar 02, 2024 2:09 pm
Anyone fitted the casa disc brake hose with the inline brake fitting. I presume unlike the venhill type the banjo isn't removable. I don't want to slot headset bottom I want to drill a hole in the side so will it have to be the size of the banjo to pass it through then find a grommet suitable to cover it.
gizmo
by pharrisRB225 » Sun Mar 10, 2024 8:31 pm
there should be the right sized grommet with the kit for the headset
pharrisRB225
by gizmo » Mon Mar 11, 2024 7:03 pm
pharrisRB225 wrote:there should be the right sized grommet with the kit for the headset
I wondered what the grommet on the hose was for. Thought it was a bit bulky for headset. Thanks for that. Will get drill out
gizmo
by jonoy » Tue Oct 22, 2024 9:20 pm
Can you tell me if you fitted this and what size drill bit used to create
the hole in headset bottom
jonoy
by Warkton Tornado No.1 » Tue Oct 22, 2024 10:32 pm
The ‘proper’ braided steel hoses comprising a compression fitting at each end, are dismantle-able so that, if you’re brave enough, the hole in the headset only need be clearance for the hose, not all the gubbins on each end…..
by jonoy » Wed Oct 23, 2024 5:50 pm
Warkton Tornado No.1 wrote:The ‘proper’ braided steel hoses comprising a compression fitting at each end, are dismantle-able so that, if you’re brave enough, the hole in the headset only need be clearance for the hose, not all the gubbins on each end…..
Iam not brave or knowledgeable enough
jonoy
by gizmo » Thu Oct 24, 2024 7:41 am
jonoy wrote:Can you tell me if you fitted this and what size drill bit used to create
. I have sent it off for engraving but if I remember right I measured centre of grommet which I think was 14mm which looks massive but is right for the rubber grommet which is on hose.
gizmo
by jonoy » Thu Oct 24, 2024 12:40 pm
gizmo wrote:jonoy wrote:Can you tell me if you fitted this and what size drill bit used to create
Thank you for the reply
jonoy
Users browsing this forum: No registered users and 15 guests
