Front sprocket touching case
Postby jdevane5 » Wed Feb 07, 2024 11:19 pm
Just building an RT230 in a SIL GP150 & Looks like the front sprocket is just touching the inner case when assembled..
I've checked sprocket and all put together correctly.
Question is do I need to fettle the inner case? It's only just touching by a nats c...
It's a SIL case.
JD
jdevane5
Re: Front sprocket touching case
Postby hullygully » Thu Feb 08, 2024 12:14 pm
fettle it, If you use a thicker dished washer then you'll have a knock on effect with the clutch alignement IMHO
Postby Covboy » Sat Feb 10, 2024 8:38 am
Maybe a thicker gasket ?
Postby Knowledge » Mon Feb 12, 2024 12:13 am
Are you saying that the top of the front sprocket stack is touching the inside of the chain case cover?
If so, then I would suspect an incorrectly assembled spring alignment. Try the hammer-test on the top of the spring retainer. If the hammer bounces, it is good. If it goes “clunk”, then take it apart and try again.
(Sorry if I have misinterpreted your OP)
Users browsing this forum: Bing [Bot] and 6 guests
