lofty wrote:depending on the sensitivity of your meter the two 'non earth' wires will still show almost earth (and may 'beep' on a continuity tester)..
real earth should be noticeably less than 1 ohm, the others typically anywhere between 5-100 ohm (guess)..
unless the wire is trapped under the stator and pinched through the insulation, which would then mean all wires could show a true earth, but then nothing would work or light up..
ULC Soulagent wrote:I’ve a few spare Casa stators so I’ll check
a-teamlambretta wrote:ULC Soulagent wrote:I’ve a few spare Casa stators so I’ll check
Thanks...this what I was hoping for.
Cheers Simon
jonoy wrote:Can you still buy casatronic stators ?
a-teamlambretta wrote:jonoy wrote:Can you still buy casatronic stators ?
Yes £120...on top of the kit that costs the thick end of £500 ...hence wanting to make sure that it is a faulty stator before lashing out on a new one.
jonoy wrote:a-teamlambretta wrote:jonoy wrote:Can you still buy casatronic stators ?
Ok i have the previous casatronic and was wondering if you can still buy a replacement stator for it
Users browsing this forum: Bing [Bot] and 8 guests
