Fast n Furious wrote:When you stripped it down, was your cluster gear fitted with the 30 x 16 x 1mm bearing retainer shim?
Normally the bearing here is a 16 x 22 x 12. I've seen it where the bearing has been substituted with a 16 x 22 x 14. resulting in the omission of the bearing retainer shim.
