RT225 kit Cylinder head question
Postby jdevane5 » Fri May 05, 2023 11:30 pm
Any one out fitted a RT 225 kit cyinder head with the 8 fixing setup?
I've just spotted something on my kit and after advise....
Why are the cylinder head holes for the four long cylinder studs threaded?
The holes in the cylinder head for the 4 additional head bolts are not threaded (as expected) and screw into the cylinder barrel.
Cheers :D
jdevane5
Re: RT225 kit Cylinder head question
Postby Wack » Fri May 05, 2023 11:44 pm
I'd say the threads were used to hold the head for machining.
Postby dickie » Sat May 06, 2023 7:21 am
Wack wrote:I'd say the threads were used to hold the head for machining.
That's right. I asked MB once.
Postby jdevane5 » Sat May 06, 2023 3:16 pm
Thanks alot Both -Mystery solved - bolt down holes for CNC' ing :D
jdevane5
