by Storkfoot » Tue Apr 25, 2023 1:36 pm
Am I correct in believing that there is no need for a spacer on where the shock absorber (Protech/Chiselspeed adjustable) mounts to the engine?
The need for a spacer is when you fit an Italian engine to a later Spanish frame. Is that right?
by ULC Soulagent » Thu Apr 27, 2023 4:25 am
That’s correct although I always fit shim washers regardless
ULC Soulagent
by Storkfoot » Thu Apr 27, 2023 7:27 am
Thanks. I ended up measuring an Italian casing and, yes, the stud attachment on the casing is virtually identical dimensions. It is also situated in the same position.
Users browsing this forum: Bing [Bot] and 15 guests
