by Bilko » Sun Feb 19, 2023 1:33 am
I’m looking a basic electronic kit for a friend’s standard LI150. But the nearest to basic is the Scootopia Variable one. Would a variable version not be overkill for standard?
There doesn’t seem to be much else apart from the SIP Vape.
Bilko
by Tractorman » Sun Feb 19, 2023 9:28 am
The scootopia is good I have fitted several without any problems.
by Bilko » Sun Feb 19, 2023 10:32 am
Thanks.
Yes, I hear it is, but was wondering whether it was necessary for a standard set up. There doesn’t seem to be anything else.
Bilko
by Storkfoot » Sun Feb 19, 2023 1:19 pm
AF still sell kits and individual Stators and mid weight electronic flywheels. I have used one of their Elemec flywheels on my TS1 for 12 years without issue. I can’t vouch for their Stators but you could buy a bgm one separately, if you wanted.
by Leotech » Sun Feb 19, 2023 8:32 pm
I have just put a Scootopia one on a standard LI150, improved the starting and lights no end. Mate was very happy.
Leotech
by Bilko » Sun Feb 19, 2023 9:53 pm
Thanks for the replies.
Bilko
by Micky67keane » Fri Jul 14, 2023 8:41 pm
I use a Scootronics stator,cdi wassel rectifier and a midweight flywheel.Never missed a beat,great back up from Anthony and doesn't break the bank.
Micky67keane
by coaster » Fri Jul 14, 2023 11:24 pm
Micky67keane wrote:I use a Scootronics stator,cdi wassel rectifier and a midweight flywheel.Never missed a beat,great back up from Anthony and doesn't break the bank.
Same here, his stators are fantastic quality with very good lighting output and as Storkfoot says, AF sell good mid weight flywheels. I've also used a couple of BGM stators which have never let me down.
by bookertmgs1 » Mon Jul 17, 2023 10:02 am
Not sure why you would need an all singing / dancing set up for a std LI150
A standard electronic stator / flywheel combination would be sufficent and probably achiveable for under £150 inc regulator & cdi. Also has the benefit of having easy access to spares if required.
bookertmgs1
Users browsing this forum: Google [Bot], LambrettaMarky, nsaints and 20 guests
