Leather panel straps
Postby shane BBoys » Mon Oct 10, 2022 3:47 pm
Hi.
I’ve just picked up a Spanish S2 and was looking at fitting some leather straps I’ve seen some at Demon Tweaks but unsure if these would fit, I cannot find any dims to check with? Any help would be much appreciated
https://www.demon-tweeks.com/demon-twee ... lsrc=aw.ds
https://www.demon-tweeks.com/omp-leathe ... lsrc=aw.ds
Cheers Shane.
shane BBoys
Re: Leather panel straps
Postby SlackerThePinstriper » Mon Oct 10, 2022 4:47 pm
Buy a couple of cheap belts from home bargains and some steel/brass plate with some decent nuts and bolts or rivets 8-)
Postby gaz_powell » Mon Oct 10, 2022 7:31 pm
I ve had a pr of the cheaper ones for a while, wanted to put them on my not so well fitting spanish SX panels.
Im away from home so can measure them when im back Friday.
I could never decide where to put them.
Was gonna drill the the tool box door and strap to front of panel, thats were mine are a big baggy
Keen to see what others have done, could never find any photos
Would think S2 paneks might lend themselves better than S3
Postby shane BBoys » Mon Oct 10, 2022 7:58 pm
SlackerThePinstriper wrote:Buy a couple of cheap belts from home bargains and some steel/brass plate with some decent nuts and bolts or rivets 8-)
Shows how long it’s been you’ve been out! A leather belt if you are lucky is £15
Any how might need you again on this 1.
Cheers Shane.
shane BBoys
Users browsing this forum: No registered users and 17 guests
