MickYork wrote:You can try testing the pick up and coil with a resistance meter but to be honest this is a bit hit and miss with different manufacturers having different readings. Sticky's gives a bit of info' about this. The easiest way (sort of) is to replace with a known good stator (and re-time).
I don't think it's a top end issue and the stator would be favourite, but never rule out something obscure or obvious (have you changed the plug !).....dodgy fuel is another one for the "well who'd have thought it was that" list.
Good luck and keep us posted with updates.
