New TS1
New TS1
Postby shane BBoys » Sat Aug 06, 2022 10:41 pm
Just in the process of picking up my recently rebuilt motor and I was thinking of running it from its 1st fill up using groundsman oil I’ve read of a few using this oil what % should I use?
I have 20 litres which I pick up and usually run on rock oil
Cheers Shane.
shane BBoys
Re: New TS1
Postby Toddy » Sun Aug 07, 2022 3:47 pm
I run it it 3 of my motors for the last 5 years all 4% been fine
Re: New TS1
Postby MickYork » Sun Aug 07, 2022 4:18 pm
Did a 1000 miles on my Avanti running in. Country roads, plenty of gear changing and up and down with the rev's. Used 4% SIP and the rings got stuck up with too much carbon. 4% was too rich for running in. With not giving it the rev's and heat it needed it wasn't burning off the oil. Would start with 3% if i did it again. I now run @ 2%.
Re: New TS1
Postby gaz_powell » Sun Aug 07, 2022 5:43 pm
Im using groundsman in 2x TS1 nicosil barrels and a steel lined TS1 plus a steel lined ali Vespa 210, all on 3%.
Im very happy with it, Ive just bought another 20litres.
Re: New TS1
Postby martyn dwane » Mon Aug 08, 2022 11:26 am
3% Groundsman in my Ts1 200 and Reed valved Rapido 225.
martyn dwane
Re: New TS1
Postby shane BBoys » Mon Aug 08, 2022 12:25 pm
Thank you all for your reply's it is much appreciated I will use up the rock oil that I already have on my P2 and use from now on the grounds man in my Rapido and when the TS is ready she will see nothing else but GM..
Cheers Shane.
shane BBoys
Users browsing this forum: Google [Bot] and 1 guest
