48mm VW clubman exhaust system.
Postby kevspeed » Sun Jun 19, 2022 10:07 am
Hi all.....Has anybody had any luck quietening down a VW clubman pipe? Dont get me wrong...i love the sound,but this one is loud,and i mean LOUD!
If i could reduce it by just a few decibels it would be good enough,but at the moment its way over the top. I have the perforated internal baffles to fit inside (i cut the exhaust in half to get the old rattly stuff out),but while its apart is there anything else i could do to reduce the noise?
kevspeed
Re: 48mm VW clubman exhaust system.
Postby missing lynx » Sun Jun 19, 2022 11:32 am
I seem to remember a mate in the 80's had one and by moving the VW pipe in or out changed the tone but not sure if it went any quieter
Postby Warkton Tornado No.1 » Sun Jun 19, 2022 12:34 pm
It is a fact that with an expansion chamber being conical, it's fairly easy to assess where the 'baffle' is as it is immediately behind the cylindrical belly section. If a pipe is internal just a little longer than the baffle, it will quieten things down before the tailpipe is reached by the escaping gas. However, a guesstimate can be made with a 'box with just a big bore 'U' pipe, though if your system is also a reverse cone, then as per an expansion chamber.
If you have a go @ adding such an internal pipe, it needs to be comfortably bigger in diameter. I'd go for 25 mm bore tube.
The problem remains that the VW mufflers are too small & can cause heat build-up in the cylinder as well as often getting blasted to bits.
I've got it in mind that somebody created a similar exhaust using an MGF muffler.
Postby kevspeed » Mon Jun 20, 2022 8:50 am
Seeing as I have the pipe cut open, I'll have a go with the extra length of pipe inside. On
kevspeed
Users browsing this forum: No registered users and 21 guests
