Piston identification help needed
Postby phil23fair » Fri Mar 04, 2022 7:35 pm
I bought a second hand iron lined TS1 kit which now needs a rebore. The existing piston crown is marked 70.45 diameter and 19413-4. There doesn’t seem to be any other identification marks. Can anybody help me with what the make of this piston is please
phil23fair
Re: Piston identification help needed
Postby Fast n Furious » Fri Mar 04, 2022 10:24 pm
That would be a grade "A" piston for a 70.50mm bore.
Is it a 16mm or 18mm gudgeon pin and whats the crown height? (centre of the pin to the top of the piston wall)
If you could post some photo's then someone on here will probably recognise the make or suggest some good oversize options.
Postby phil23fair » Sat Mar 05, 2022 10:37 am
It’s a 16mm gudgeon pin with a 39mm crown height. It’s also got W665-T cast inside the crown. I don’t know how to post pictures on the forum and I don’t have time today but I’ll investigate and see if I can get some up tomorrow
phil23fair
Postby gaz_powell » Sat Mar 05, 2022 11:16 am
Postby phil23fair » Sat Mar 05, 2022 11:33 am
Thanks for that Gaz. Has anyone any suggestions as to a next size up I could use?
phil23fair
Postby ste s one » Sat Mar 05, 2022 12:03 pm
I have a 71mm Wossner in a steel lined TS1 .bought from AF rayspeed with windows cut in it
ste s one
Postby phil23fair » Sat Mar 05, 2022 1:39 pm
[quoteI have a 71mm Wossner in a steel lined TS1 .bought from AF rayspeed with windows cut in it][/quote]
Thanks, I've just messaged Rayspeed about doing one for me
phil23fair
Users browsing this forum: Google [Bot] and 2 guests
