Engine case coating question
Postby TVSi » Wed Dec 29, 2021 4:31 pm
Hi all
i have just had a case aqua blasted and its come up a treat and I would like to keep it looking good. is it possible to use something like a clear engine lacquer or maybe a wax of some sort. What have you used successfully?
TVSi
Re: Engine case coating question
Postby Cgt75b » Wed Dec 29, 2021 5:52 pm
A regular clean with autosol and it should be reet.
Postby TVSi » Wed Dec 29, 2021 8:13 pm
I was thinking of something to coat the case so that it is easy wash the dirt off with a bit of Muck off or similar?
TVSi
Postby Fast n Furious » Wed Dec 29, 2021 9:43 pm
You could make some enquiries with a reputable powder coating firm regarding a high temp clear gloss powder coating.
For a more budget job, then a rattle can coating of VHT engine laquer might do, albeit with a lower lifespan than the powder coated option. Just make sure to choose a brand that is petrol resistant.
Alternatively, you could invest in some polishing kit that will fit your electric drill and apply elbow grease to restore the natural lustre.
Postby TVSi » Thu Dec 30, 2021 10:40 am
I was trying to avoid the powder coaters if possible.
looking on the web I see that Halfords do a bare metal clear engine lacquer suitable for temps of 100 degC , has anyone tried this or something similar before? did it do the job?
TVSi
Postby ULC Soulagent » Thu Dec 30, 2021 11:41 am
TVSi wrote:I was trying to avoid the powder coaters if possible.
Don’t forget that the engine acts as a heatsink so temps will be above the 100* margin I’d imagine
Me personally would use the vht exhaust clear coat paint( as stated by FnF) as a decent alternative
ULC Soulagent
Postby missing lynx » Thu Dec 30, 2021 1:33 pm
I just use a silicone based household polish which repels water and makes the muck easier to wash off
Postby TVSi » Sat Jan 01, 2022 11:50 am
Thanks for all your comments, it has given me food for thought.
Happy New year one and all
TVSi
Users browsing this forum: No registered users and 15 guests
