Adam_Winstone wrote:Watch out for a number of other features/factors:
1. Ring ends and ring peg shapes. You will often find that peg shapes and depths (height of peg) differ and that the end of the ring is profiled to fit that specific shape. Other rings may not fit and/or apply additional pressure on the ppeg.
2. Ring cross section - rings are not always flat. It is quite common for rings to have a slight wedge shape, whilst others do not.
TBH I would continue to look for the correct ones, specific to your piston.
Your best bet might be to try to speak with Cambridge Lambretta on the phone, they should be able to advise or supply.
Users browsing this forum: Solid Air and 6 guests
