Mk 1 Bambini
Mk 1 Bambini
Postby Skippy » Thu Nov 06, 2014 3:58 am
Not too sure if this is the right area to post this, but, I have finally completed sourcing everything to fit my Mk 1 Bambini to my Series 2, except for a couple of fasteners which I had assumed would be the least difficult things to find. I need to find the correct 4 bolts to hold the two piece frame tube clamp together(the bit that grabs the scooter frame tube), and the correct 2 bolts to secure the pinch clamp part of the same piece. All or a sample of either would be great, but just the specs so that I can make them would also be greatly appreciated too.
Skippy
Re: Mk 1 Bambini
Postby Digger » Thu Nov 06, 2014 5:58 am
Don't Anson Classics make everything for this?
Digger
Re: Mk 1 Bambini
Postby Tractorman » Thu Nov 06, 2014 9:54 am
Yes Anson Classics will have the parts.
Re: Mk 1 Bambini
Postby Skippy » Thu Nov 06, 2014 11:54 am
Yes, they do everything except the bolts!
Skippy
Re: Mk 1 Bambini
Postby Digger » Thu Nov 06, 2014 3:20 pm
Are they 'special' or just bolts?
Digger
Re: Mk 1 Bambini
Postby Tractorman » Thu Nov 06, 2014 6:38 pm
Skippy wrote:Yes, they do everything except the bolts!
I got all the bolts with mine, around a month ago.
Re: Mk 1 Bambini
Postby Skippy » Thu Nov 06, 2014 9:02 pm
Apparently, yes, they are a special shoulder bolt peculiar to the original clamp unit, Ansons told me using normal bolts may cause the clamp to bend/snap rather than pulling down uniformly due to the precise fit of the shoulder in the cast holes? My kids are going in the sidecar so I need to get it right. I even tried Watsonian direct and they do not even hold the drawings for it, although they are aware of its need to be exact in size and shape too.
Skippy
Users browsing this forum: Gary21 and 25 guests
