series 2 wiring dilemma
Postby HxPaul » Wed Nov 05, 2014 3:08 pm
I have a series 2 that I'm building.I have decided to use a 12v system and instead of a cut out button I've decided to use a three position ignition switch,on,pilot light,headlight.I'm also using the series 2 handlebar light switch for dip,main beam and horn.What I would like to know is,which wire would be the main feed to the switch,I know that red and blue are dip and main beam and white is the horn,which leaves,black,brown,yellow and purple,of these four which would be live,or do I conect them all up to the live feed.
Re: series 2 wiring dilemma
Postby St George » Wed Nov 05, 2014 6:13 pm
Hi Mate.
Stickies book has all the diagrams in it and makes very good reading.
St George
Postby gaz_powell » Wed Nov 05, 2014 8:37 pm
http://img.docstoccdn.com/thumb/orig/157590166.png
I used the simple harness,with a s2 light switch with 3 position ignition switch all as this diagram
gaz
Postby neil64 » Wed Nov 05, 2014 8:54 pm
yeah look at stickys mb simplified loom for a/c key with li switch.I think i have the same system on my 1964 eibar winter model but im not going to take the handlebar top off to find out ,good luck.
neil64
Postby Digger » Thu Nov 06, 2014 6:00 am
I have it on my S1 and my S2.
A multimeter is a great help when messing aroung with electrics.
Digger
Postby HxPaul » Fri Nov 07, 2014 7:12 pm
Thanks for all the answers.I have stickys manual but its for slimstyle scooters and none of the wiring diagrams show the series 2 handlebar switch that I'm using.I'll try using a multimeter and see if I have any joy.
Postby Captain Pugwash » Fri Nov 07, 2014 8:21 pm
HxPaul wrote:Thanks for all the answers.I have stickys manual but its for slimstyle scooters and none of the wiring diagrams show the series 2 handlebar switch that I'm using.I'll try using a multimeter and see if I have any joy.
PM sent
Captain Pugwash
Postby gaz_powell » Tue Nov 11, 2014 8:44 pm
Did you win ?
Postby Tractorman » Tue Nov 11, 2014 9:36 pm
neil64 wrote:yeah look at stickys mb simplified loom for a/c key with li switch.I think i have the same system on my 1964 eibar winter model but im not going to take the handlebar top off to find out ,good luck.
This diagram is no longer up to date, for the latest go into MB's tech webpage.
Postby HxPaul » Tue Nov 11, 2014 10:35 pm
gaz_powell wrote:Did you win ?
The headset is away being painted at the moment.When I get it back from the painters I'm going to try wiring it as per the diagrams sent to me in a PM from Captain Pugwash.
Users browsing this forum: Google [Bot] and 10 guests
