E10/etahnol resistant Seals
Need specific detail for a particular model, or just found something strange and interesting and want to know if its original. All attention to detail seekers report here!
Strict no chatter
Postby Darky » Fri Jul 30, 2021 5:41 pm
You may be considering changing your seals so you are up to date with the new E10 fuel that's coming in September 2021 so please start to add to this post and supply links to help each other out https://www.scooter-center.com/en/oil-seal-set-engine-bgm-pro-fkm/viton-e10/etahnol-resistant-lambretta-li-125-150-serie-2-3-lis-sx-tv-serie-2-3-gp/dl-bgm1141
Darky
Re: E10/etahnol resistant Seals
Postby gaz_powell » Mon Aug 16, 2021 12:40 pm
Why use a Viton seal on anything other than around the crank where the petrol is.
No benefit at kickstart and rear hub....
Postby hullygully » Mon Aug 16, 2021 1:26 pm
+1
garages round our end are starting to use E10 95 alongside E5 97
Postby neily03 » Mon Aug 16, 2021 1:45 pm
Super is staying E5 so just use that.
neily03
Postby Darky » Mon Aug 16, 2021 10:42 pm
Be careful I just filled up with E10 at Pitsea Tesco
Darky
Return to Anorak's Corner
Users browsing this forum: No registered users and 2 guests
