exhaust repacking
exhaust repacking
Postby george747 » Sun Nov 02, 2014 6:58 pm
Hi,i need to repack the baffle wadding,will I just drill the rivets,clean out,and repack? EG, how much wadding,loose stuff?,or the flat roll stuff? or any tips.Thanks PS its a sterling pipe
george747
Re: exhaust repacking
Postby Digger » Sun Nov 02, 2014 7:37 pm
I use the roll fribre stuff.
A lot of texts say roll it as tight as possible but I have found that doing that tends to make it clog up quicker right around the layer next to the perforated steel tube so it needs re-doing in a few months.
The last one I did I simply cut off the first bit that was coked up and stuck it back in - works fine.
Digger
Postby mr series 2 » Sun Nov 02, 2014 8:39 pm
Ive always wrapped the stinger first with wire wool then the sheet wadding stops it cokeing up so fast
mr series 2
Postby Toddy » Mon Nov 03, 2014 7:02 am
^ agree with suggestions above, dont Pack too tight either
Postby Scooterlam » Mon Nov 03, 2014 7:27 pm
I just done one with loft roll, not very tight. Quietest can I,ve ever had.
just got to see howvlong it lasts?
Scooterlam
Postby coaster » Mon Nov 03, 2014 8:02 pm
As above, use the roll, not the loose stuff and don't over stuff.
Postby george747 » Mon Nov 10, 2014 5:55 pm
Hi ,thanks for your tips,just fitted and its defo louder??,so I haven't put enough in?,would that be correct?
george747
Postby coaster » Tue Nov 11, 2014 1:50 am
Possibly but could also be too tight
Users browsing this forum: Bing [Bot] and 8 guests
